0 registered members (), 10 guests, and 1 spider.
Posts36,789
#32435 - 01/28/22 02:57 AM Smartrise "Redun. LRM" ERROR
ASME17 Offline
Delaware
ASME17  Offline
Delaware
I am getting "Redun. LRM" error in a Smartrise C4 controller. Does anyone know how to fix that?
Checked the C4 manual but couldn't find it there, See the quality of their board in their own manual picture: Smatrise C4 Manual mad
#32437 - 01/28/22 03:21 AM Re: Smartrise "Redun. LRM" ERROR [Re: ASME17]
wltr00 Offline
wltr00  Offline
If the RDC jumper is on the MR SRU, the board is bad and needs to be replaced.
#32444 - 01/29/22 01:52 AM Re: Smartrise "Redun. LRM" ERROR [Re: ASME17]
This is probably one of the most annoying things about smartrise. They act like parameters and fault codes and certain info is a secret. So many times I've gotten a fault and look it up and it's not in the book. If you need a parameter changed you pretty much are going to have to call them. The unintended motion test procedure in their manual wasn't right, I had to figure out where they'd put steps backwards and make notes in the book, they'd messed up the order of holding a contactor and putting on a jumper.
#32451 - 01/30/22 08:29 PM Re: Smartrise "Redun. LRM" ERROR [Re: EElevator]
liftronic Offline
LA Elevator
liftronic  Offline
LA Elevator
US
LRM is the "Lock Rear Middle" input which is the input for all mid-floor locks of the rear door. Those high-voltage inputs tend to fail a lot and you have to change the board
[img]https://im.ge/i/XwqAeq[/img]
Page Time: 0.035s Queries: 17 (0.008s) Memory: 2.6698 MB (Peak: 2.8218 MB) Zlib disabled. Server Time: 2024-04-19 21:09:08 UTC
