1 registered members (Gurunath), 15 guests, and 0 spiders.
Posts36,783
Page 2 of 2 1 2
#33108 - 05/19/22 09:50 PM Re: TK LD-03 interface [Re: ashley]
Just replaced a smartrise brake board, capacitor literally blew the top of itself out. Seems like they're using too small components and pushing them too hard.
#33111 - 05/20/22 12:00 AM Re: TK LD-03 interface [Re: EElevator]
Alex_ELMAN Offline
Miami Elevator
Alex_ELMAN  Offline
Miami Elevator
It is ridiculous! @EElevator, can you share a picture of that
They have recently announced they give 5 years warranty for all these low quality and wrong designed controllers! How can they afford 5 years warranty when the drive manufacturers, soft-starter manufacturers, contactor manufacturers and even electronic board component manufacturers have maximum a couple years warranty for the parts! Then Smartrise put them together, like a wrong puzzle, and give 5 years warranty!? THEY ARE TRYING TO SELL AS MANY CONTROLLERS AS THEY CAN AND THEN CLOSE THE COMPANY IN A COUPLE YEARS. Right now they have terrible technical support, in a couple years there will be NO technical support and NO spare parts. Just my thoughts
#33322 - 07/01/22 02:11 AM Re: TK LD-03 interface [Re: ashley]
JJR Offline
JJR  Offline
I would recommend either the GAL MONXT or the Wittur SGV (AMD and LD-16 similar), especially if the building is prone to vandalism or heavy use.
Both of these door operators are European style, which typically have more safety features, such as cabin door interlock (no gate switch, which could get purposefully or inadvertently activated at the wrong time, and no "less reliable" door restrictor, which could become a snag hazard, in the case of the angle-iron variety, or purposefully jammed in the unlocked position by a tech, in the case of the GAL/MAC?Miami Elevator variety, or even worse jam in the locked position with dead battery, in the case of Adams HatchLatch). With interlock, door cannot be moved ajar. Also, no need for ugly sheet metal between landings on glass jobs. The clutch engages independently from the door movement, reducing a snag hazard due to misaligned doors. The doors can't be split apart at floor level causing door lock faults due to the clutch design.
In your case, I would recommend the Wittur product because it comes with a kit allowing you to retain your existing Miami Elevator hall door equipment; however you will have to replace the tracks on the cabin side and also the skate. Also, parts are available from multiple sources (KONE, TKE/Vertical Express, and Wittur) Link: https://verticalxpress.com/media/download_files/component_manuals/ld_16_udo_mod.pdf
The second choice would be the GAL MONXT. Unlike the Wittur product, you will need to rehang the doors with GAL hardware and also replace the door skate and the hall locks. This might be acceptable for just a few stops.
Flyer: https://www.gal.com/wp-content/uploads/2020/06/GAL_MONXT.pdf
Installation: https://www.gal.com/wp-content/uploads/2021/01/MONXT-Operator-Installation-Manual-DELTA.pdf
Whatever you do, I wouldn't recommend harmonic op. They are just too outdated and don't offer all the safety features of Euro style operators. GAL is the only company that still makes em. They need to stop, lol. Especially in today's day and age. See first paragraph to learn more. Another downside to harmonic ops is that same make and models can become self locking (operator can move the door but door can't move operator). This can cause problems during entrapment where the only way to get the door open is to climb on top and spin the infamous wheels. This can be dangerous is you have long floor runs (i.e. train stations). With linear operators, they are never self-locking. They can be easily opened from the floor or cab top. The amount of force needed is always uniform throughout the entire door cycle, to manually open the door. Plus, if the power is cut, the clutch is spring-loaded. If elevator is at floor during an entrapment, all that needs to be done from the outside is cut the juice and then manually open the door (no key or lock picking). If door arm bolts get loose or detached, they could fall on someone. With a belt operator, if the belt breaks, it will just loose traction and stop. Another bad thing is when they are used on glass door installs (propped up on pedestals. This creates trip hazards for workers and adds installation costs for taller hoistway.
If you really wanna see how dangerous a gate sw is. Check out this vid. Be glad it was equipped with DLM: https://www.youtube.com/watch?v=AEOkZDBCDiw
#33324 - 07/01/22 02:22 AM Re: TK LD-03 interface [Re: ashley]
I think I attached the photo..
Page 2 of 2 1 2
Page Time: 0.040s Queries: 17 (0.016s) Memory: 2.6851 MB (Peak: 2.8381 MB) Zlib disabled. Server Time: 2024-04-19 08:39:51 UTC
