0 registered members (), 18 guests, and 4 spiders.
Topics6,515
Posts36,880
#37275 - 04/17/24 12:35 AM DMC Door Issue
wltr00 Online content
wltr00  Online Content
Getting a 313 & 317 door fault on a DMC. Only getting 4V on my 5VDC on the door board, so only get 2V on my phase outputs instead of 2.5V. Have a PY2 door board. Any suggestions?
#37285 - 04/18/24 01:55 AM Re: DMC Door Issue [Re: wltr00]
317 is your pulse cont is off and needs a relearn probably.
313 did reach door open limit.
#37287 - 04/18/24 02:06 AM Re: DMC Door Issue [Re: lowoil]
gohana256 Offline
Another Helper
gohana256  Offline
Another Helper
have you checked the dol/dcl magnet holders are ok?
#37290 - 04/18/24 02:23 AM Re: DMC Door Issue [Re: wltr00]
I don't know, I ain't a guru on this board specifically, but most processors like their voltage where it should be. 4v is very low for the 5v supply.
#37292 - 04/18/24 11:52 AM Re: DMC Door Issue [Re: wltr00]
What is your 5vdc at in the cop?
#37324 - 04/23/24 01:33 PM Re: DMC Door Issue [Re: wltr00]
boomer Offline
boomer  Offline
There’s a capacitor in the door operator I’ve seen those cause weird problems.
#37335 - 04/25/24 07:00 PM Re: DMC Door Issue [Re: wltr00]
Tramguage1 Offline
Tramguage1  Offline
my moneies is on the power supply in the COP. There starting to get that age.
#37360 - 04/28/24 06:22 PM Re: DMC Door Issue [Re: wltr00]
Alto101 Offline
Alto101  Offline
Central Florida
We recently modernized 3 DMC’s. Best decision ever. Those darn operator are a pain, constantly recycling and minor adjustments that are very time consuming. Alpha controller with wittur LD 16 drive only retrofit. Haven’t had a single call in months.
The better the effort, the better the result.
#37375 - 04/30/24 08:46 PM Re: DMC Door Issue [Re: Alto101]
ashley Offline
ashley  Offline
Alto101 :
Did you get the LD 16 thru vertical express or Wittur direct?
Page Time: 0.039s Queries: 17 (0.015s) Memory: 2.7109 MB (Peak: 2.9041 MB) Zlib disabled. Server Time: 2024-05-04 02:58:34 UTC
