#6017 02/26/13 11:29 PM
Had someone knock door off track. Put back on and have 202 fault. Doors will close but won't open. Do not have extra info code. Any ideas? Thanks
beaupeep #6019 02/27/13 02:15 AM
202 is a generic door code. Look through some of the earlier Schindler 330a posts. If you click on technical questions then click subject you can find everything listed as 330a and Schindler 330a.
Is there a smlcd on the controller?
Are you sure the car gate is fully closed?
jkh #6023 02/27/13 07:19 PM
Extra info code is 00000001
beaupeep #6024 02/27/13 09:49 PM
So if the doors will close but not open!
Is your close limit functioning properly?
jkh #6026 02/27/13 11:25 PM
Jkh, talked to another mech and he said could be door op board in cop could of fried after trying to open with door being knocked off, ever seen that
beaupeep #6030 02/28/13 02:12 AM
Anything is possible!
What have you checked so far?
Do you have prints?
Did you check your inputs for your limits?
jkh #6034 02/28/13 03:23 AM
Use the test switch on the TDC board in the car station, that'll rule out the board.
E-man #6046 03/01/13 03:34 AM
have you tried to kill power and shot the "cap"? make sure the doors are closed when you boot back up let them do a learn run
beaupeep #6064 03/01/13 10:44 PM
PGL Offline
ELEVMAN
ELEVMAN
extra info 01=KET-Oand KET-s are active at the same time did an open or close limit get damaged?
PGL #6067 03/02/13 12:51 AM
E-man, tried from tdc board to open but wouldn't work but still closes. We sent the board in for repair. Are any of the pots on the bottom of board for current limiting? Thanks for extra info pgl
beaupeep #6073 03/02/13 06:45 AM
Is the OL a proximity switch?
E-man #6088 03/04/13 05:58 PM
Thanlks for help guys, ended up replacing ol proxy. Is there any write up for the pots at bottom of tdc board or adjustment procedure for door op.
PHP: 8.3.33 Page Time: 0.070s Queries: 38 (0.049s) Memory: 3.0493 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-20 20:23:31 UTC
