1 members (sampler), 31 guests, and 3 robots.
#6557 04/10/13 05:51 PM
hy...i am new here and i have some problem with kone monospace.on rescue drive evevator is runing normal.when i put it in normal drive it runs until next station and when come on switch 61n stops immediately and than shows error 00 42....i saw in error list and it writes something about car light supplay...It does not make sense.help if you can
thanks and sorry about my english...is not perfect
if the car light voltage is missing from the car top ccbn board, the car will shut down. you may want to check the voltage there. parameter 77 in menu 1 is the car light supervision parameter. 0 is no car light supervision, 1 is supervised car light. if you are actually losing the voltage for your lights, you could have a bad travel cord, or bad connection on the ccbn board. good luck.
but whole time i have light in car.i will check but i am sure that car light is whole time on.car dont stop in station but few centimeters before station...it make no sense car light supply missing
Service Manager
Service Manager
in the cop box there is a board under this board is a battery for the emergency light if this battery is going low it causes all types of "issues" may be worth the look!!
hey i am back....i changed baterry (it was 5 V ) and changed parameter 77 into 0(no car light supervision).after that elevator is running normaly...but....whole time button alarm,emergency light on inspection box and ecodisc in car light....after 7 days battery had about 10 volts and now doesent work alarm and emergency light in car.have any ideas?thanks
Looks like a shorted cob24 or a stripped wire on the dc side grounding
PHP: 8.3.36 Page Time: 0.036s Queries: 26 (0.013s) Memory: 3.0191 MB (Peak: 3.5904 MB) Data Comp: Off Server Time: 2026-11-06 10:41:38 UTC
