#6948 05/09/13 02:35 AM
hello all
i have a kone monospace working on and a keep getting missing 61u,i change the 61u and still getting the same problem,i change the board on top of the lift and still getting the same problem,any input
Hi,
Is it missing all the time or every now and then? If so have you got too much play in top shoes, and did you do a shaft setup?
Dmhughes #6960 05/09/13 07:12 PM
it misses it all the time and we hve adjusted the switch as close as possible to the magnet
the magnet could be upside down.
john jay #6963 05/09/13 08:50 PM
the 61u/61n magnets can turn in any direction unlike the 77u/77n so its something else
Is this after a shat setup, and have you done a lon download after changing boards? & Are you getting any other fault codes, also what's the distance between the 61u & 61n it should be 128/130mm centres, believe it or not I've had one that was causing havoc with 61 switches & it was down to a faulty tacho (strange)
Dmhughes #6970 05/10/13 05:48 PM
Service Manager
Service Manager
sounds like you need to do adon learn and lon download
bk2fla #6973 05/10/13 09:58 PM
elevator lifer
elevator lifer
bad adon possibly
PHP: 8.3.33 Page Time: 0.020s Queries: 30 (0.005s) Memory: 3.0301 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 11:59:14 UTC
