Hello,
I would like to know if anyone has changed these drives and if there is a set of parameters that has to changed or it fits by default,i have a monospace elevator 1000kg, 1 m/s.
Thank You.
The parameter and software upgrades info comes with the drive when ordered through kone spares
If only Kone didn't cheap out and use this drive in the first place with encoder control. Then again, they sold a hundred thousand of them.
Hi,
Yes, I've fit loads of 16Ls but done my first KDL today, went well, all instructions come with it, there are some cable adapters a new brake & thermistor loom, you have to split the pods into separates ie 4 wires, encoder instead of tacho, & batt backup cable to connect into SEP, parameter address changes all in the paperwork that comes with it, just a bit more tricky than 16L.
I have the document should you need it.
Hope this helps
Dave
Hi Dave
Should I install the kdl16. Posted by kone in the kit there are not instructions
could you send me the instructions for e-mail?
my email address is: [email protected]
thanks
greetings
Andrea
Hi Andrea
Check email.
Dave
Hi Dave ,
Could I look at those instructions as well ?
[email protected]
Hello Dave,i need instructions for changing V3f16L with new KDL...thanks
[email protected]
Don't get too excited about these new drives. Lots of reports about the new KDL's failing already.
Oh man ! Don't say that. What's happening with the KDL's now ?
Same old story and it is across the KDL range 16's 32's etc.and including KDM models
Keeps us employed I suppose
Secondary market is gonna make a fortune out of this.
My kdm and kdl's are doing fine, no problems keep your brake nut loose and rails oiled you will be fine.
I have had a number of these go at aprox. 5 years...do they had a timed mini bomb in them hahahah like the old eng service light for egr ..reset it and charge them 10 grand
Hi Dave
Please could i have those instructions as well ?
i got the unit without instrctions
many thanks
abukul
Hello guys ,i need instructions for changing V3f16L with new KDL...thanks
[email protected]
Hi dears any one know about the kone KDL16 s replacements procedure. Please help me . I have error 126 but I was tried to find .
Can anyone help me with the parameters pdf for replacing Kone V3f16l drive with KDL16L drive.?!
What's your email?
PHP: 8.3.33 Page Time: 0.031s Queries: 54 (0.010s) Memory: 3.0927 MB (Peak: 3.5924 MB) Data Comp: Off Server Time: 2026-09-21 06:19:58 UTC
