Does anyone know the process to disable the loadweigher unit for the 400A MRL. Can we do this from the SMLCD board on the controller?
Elevator keeps cancelling car calls after several are placed as if it is a type of anti nusiance dumping.
thats probably because its been set up that way...dont know the answer but im sure you cant diasable loadweighing!!!...there must be a parameter somewhere to increase the anti-nuisence value...or might just have to set up the loadweighers again.
Anti nuisence is generally set via specfic pre set weights. Check the settings but its more likely your loadweighing is out and should be retested and zeroed.
Does anyone have a testing procedure for this unit? I don't want to miss a step rezeroing the loadweigher.
I am about to load test as well, so any information would be valuable to me.
Sorry mate 'swindler' is 1 company i've never really had much dealings with.
PHP: 8.3.33 Page Time: 0.019s Queries: 24 (0.005s) Memory: 3.0147 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 12:15:25 UTC
