#7016 05/14/13 05:24 AM
Is there any other way that i can access the parameters of the Kone Monospace without using a KNX board?
jericho #7024 05/14/13 02:28 PM
No. At least not on our version here in the states.
Philly #8951 11/10/13 11:48 PM
If you don't mind loading all parameters you can just stick in a blank NVRAM which will give you access to LCE menus
koneisland #8954 11/11/13 03:44 AM
Proud IUEC Member
Proud IUEC Member
Are we talking about KCM 831 controls? If so,you can access parameters using a 9 pin serial link cable and null modem adapter via hyper-terminal. I just recently did it to copy all parameters to a text file to save on my laptop. I have a step by step write up explaining how, if anyone is interested. I am pretty sure you can use hyper-terminal to access parameters on all Kone LCE based controls. I have personally made parameter changes using it on Miprom HS.
PHP: 8.3.33 Page Time: 0.043s Queries: 22 (0.015s) Memory: 3.0107 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 13:19:40 UTC
