1 members (sampler),
Posts: 6 |
Hola compa�eros de casualidad alguien podra ayudarme con este problema
Tengo una maquina KONE mx20l de las llamadas monospace que necesita ser embobinada nuevamente ya que sufrio un corto circuito pero lo malo es que intentaron repararla y solo le sacaron el alambre magneto de cobre y no la repararon ahora su estator esta sin embobinar ni datos, y me gustaria saber que datos en el embobinado deve de llevar?? Tengo lo siguiente Tiene 144 ranuras lleva 72 grupos de 2 bobinas en media ranura Conexion YY seccion de alambre lleva 8 hilos de calibre #20 awg y 1 hilo de calibre #18 awg
Lo que me falta saber es como va conectado el puente?? Segun la placa funciona con 283 volts 24hz a 102 RMP lleva conectado un variador de frecuencia
espero me ayuden saludos desde mexico df
Posts: 404 |
Here's the translation:
Hello fellow chance someone could help me with this problem
I have a machine KONE monospace MX20L of calls that need to be wound again as suffered a short circuit but the bad thing is that they tried to repair it and just took out the copper magnet wire and not the stator is now repaired without Coiling or data, and I would like to know which data deve carrying windings? I have the following It has 144 slots 72 has two sets of coils halfslot YY connection wire section takes 8 gauge wire # 20 awg and 1 wire gauge # 18 awg
What I need to know is how the bridge is connected? According to the plate works with 283 volts 24hz to 102 RMP has an inverter connected
hopefully help me greetings from mexico df
Posts: 262 |
Shouldn't have wasted the time or money attempting to have it repaired by a half-ass repair shop. How would they even attempt without the build data? Call kone, then order a new motor. The building has insurance to cover these sorts of situations.
Rag Man
Rag Man
Posts: 30 |
Si Kone no te da los datos del motor para arreglarlo estas fregado compa�ero. Yo no conozco ning�n taller que te puedo ayudar con eso, aqu� tienes que cambiar todo la m�quina porque naden lo arregla. Suerte y trabaja seguro.
Posts: 6 |
Hello
Do not attempt to repair KONE motor , so very dangerous . can try to KONE purchase or renovation .
