robot. |
Posts: 451 |
It's a Kone encoder Kone #US63099005. Kones spares said it would take up to 2 weeks to a month to get one to me. Trying to cross reference that number thru Adams or SEES I haven't had any luck. If someone could tell me the pulses per revolution, voltage and amperage I could get one here sooner thru another another vendor. Also I'm looking for some Allen Bradley aux contacts for my M contractor in the drive cat number 595-AB cat. B and car # 595-A cat # B. Any help would be awesome.
Posts: 451 |
Oh I forgot this is on a MiProm 21 with a Westinghouse machine
Posts: 671 |
Have you tried ZAP for the aux contacts?
Posts: 60 |
Part#us 63099005 is a 5000 ppr ,12 volt supply replaces us62675005 Use kone spares parts view that's how I've been cross referencing there parts it's worked good for the encoders so far
Posts: 262 |
We get electrical contactors and such from magtrol. Talk to tony. They are in southern California but obviously ship countrywide.
Posts: 451 |
Found the aux contacts got those in route, found the encoder from Spares but they said it will 2 week to a month. Called Adams and SEES neither of them could find a match a 5000 ppr 12v. Hopefully I have better luck tomorrow.
Posts: 262 |
Wow. Call BEI Encoders directly. That's the brand Montgomery and now Kone uses. They are here in socal, I actually do the service at there corporate office. Ironically, a two stop pumper.
Posts: 451 |
Thanks philly ill give em a shout on Tuesday, the person from adams I couldn't understand and they said the cant cross ref kone numbers and telling her what I was looking for and the specs was pointless
Posts: 262 |
Adams tech support takes days to return calls, and order takers are useless for anything but. Use the parts view on kone spares site. Sometimes has spec info.
Posts: 419 |
As has been mentioned, it WILL be a BEI encoder. All you need is the mounting type, PPR, and operating voltage. Look on the data plate on the encoder for a model number, call BEI and order one for 1/4 the price from Kone spares, or others. Always best to go to the guys that made it. http://www.beiied.com/
Posts: 262 |
Posts: 94 |
can ken a ZAP he is the man~
Posts: 451 |
The ones from KONE spares came in and it was a BEI encoder. Next time ill go straight to the source. The Good news is the changing the encoder cleaned up the ride a lot. Customer is really happy, which is good cause waiting two weeks for parts to come in was not a good situation. I was in the dog house on that one. Now if I can figure out why this car is firing all the car calls when it hangs up on the restrictor Ill be smooth sailing.
Gray head
Gray head
Posts: 7 |
As a consultant, I represent a municipality in many of their elevator issues. Recently, one of their elevators suffered a failure attributed to an encoder. The contract maintenance company isn't responsible for the cost but is quoting $10k for the "made-to-order" part and its installation, which seems incredible to me.
Posts: 639 Likes: 4
Posts: 639 Likes: 4 |
Huh... Well Maestro, being the municipalities consultant, did you have a recommendation for your client? Just curious.
Posts: 736 |
I have a 63099004 brand new in the garage. Never been used. It is a Montgomery 5v Encoder. PM me if it will work and you want it.
Gray head
Gray head
Posts: 7 |
I said I would try to substantiate the amount or determine where it should be, which is what I'm trying to do here.
