#7601 07/04/13 11:14 PM
BSP
BSP
KEEP GETTING A RH REDUNDNACY FAULT EVERYDAY AND IT KILLING MY BRAIN. CHANGE RIBBONS.NO EFFECT.CHANGED H RELAY .NO EFFECT. READJUSTED DPM SWITCH IN GAL OPERATOR BOX. IF I TAKE OUT C4 RIBBON CONNECTION ON 2B2K BOARDI WILL GET THE RH FAULT. ORDERING NEW 2B2K BOARD .ANY IDEAS??
MBKE
had a similar problem once that turned out to be caused by one of the small white connector wires that are pushed on between two small metal pins on the board. Try pushing them a little deeper into the pins. Had run out of ideas and this was the culprit.
BSP
BSP
OK.. I will check that out in the am. I let ya know what I find.
mbke
MBKE
PHP: 8.3.33 Page Time: 0.018s Queries: 20 (0.004s) Memory: 3.0030 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-09-21 01:51:25 UTC
