0 members (), 15 guests, and 2 robots.
2nd Generation
2nd Generation
Started getting vibration felt through to the cab.
Only in the up direction and more pronounced as the car passes halfway and continues to the top floor, is at its worst nearing the top floor. The drive cabinet is also making noise consistent with the vibration.
Definitely ruled out the obvious (roller guides etc) I'm looking toward the drive. Has anyone had this happen? Trying to narrow down between tach/capacitors/scr but any ideas would be helpful. Runs great empty car going down and short floor runs going up but any high speed runs sets up a vibration.
elevator lifer
elevator lifer
check cable tension, if they are unequal this can cause havoc with the ride
2nd Generation
2nd Generation
I did check rope tension about 3 months ago doing my annuals and was ok as well as governor idler sheaves and the other usual culprits for vibes.
Its only in one direction (up empty car) and more pronounced near the top landing.
This drive is also called a Swift Quiet Drive.
Have you looked at the encoder (on the motor or any other feedback device)?
2nd Generation
2nd Generation
I did i loosened the setscrews and rotated it and didnt feel any abnormal resistance. Checked all connections between tape, cartop rotary encoder and machine encoder. Any other way of testing with field equipment?
Check the power supplies on the Vector Control Board (Quantum Drive). I think there is: +5, +15, and -15 VDC. See if there is any AC voltage on those supplies while the car is vibrating. Also, check the LEDs on the drive while its vibrating to see if any unusual flickering. Make sure your encoder wires are not near motor wires or high voltage wires.
2nd Generation
2nd Generation
No abnormalities reflected in the LEDS. The unit has been in service with no problems since 2003 and no new wiring has been added near the encoders. In the process of checking for ac on the vector board is that the current regulator mounted to the inside of the swing door? ( i dont see anything labelled vector but my information that came with the job is very limited)
I believe the main board has the test points for the different power supplies +5, +15, -15. I meant to check if there is AC riding on these filtered power supplies. I think the encoder voltage on these is only 5 VDC.
2nd Generation
2nd Generation
I didn't find any ac in the test points but i did find the power supply tucked up underneath cabinet near the fans. On the advice of a friend I ordered some capacitors for the regen braking circuit in hopes that might help, as it only vibrates when the car is being pulled by the counterweight (up empty).
Id like to replace the faulty component but gaining proprietary tech support and engineering information is next to impossible. time is of the essence and i might have to replace the drive as a whole if its possible. My concern with that is there are many configurations available and this is on a 460V mod. Might not have them at home depot
Is there anyone in north america that does exchange on these drives?
Rollaway,
Did you test it with a balanced load? Did you test it with the full capacity?
Looking at you previous post. I see you looked at the encoders. How are the encoders coupled?
it may be worth putting a hand held tach on the drive sheave, make sure you are not going faster than contract speed in the up direction.
2nd Generation
2nd Generation
I retensioned the hoist ropes today to make sure nothing changed. The customer recently told me they were moving office furniture all week before this happened.
The drive indicates the speed and it shows car is overspeeding and underspeeding back and forth. I compared this with the other car for accuracy.
Even with ropes retensioned on inspect and sometimes 350fpm i was almost feeling slip. Ropes are all sitting equally in their grooves on the drive sheave....I marked the ropes and after 15-20 runs they had moved equally up the sheave. Ropes are still within spec and were replaced in 2004.
Maybe over-lubed cables?
the first thing I always did when having these kind of problems was to first replace the velocity encoder, making sure the counts and voltage on the new encoder were correct. Its really hard to check an encoder, and it takes 1/2 hour to replace one. Are any of the encoders driven off the governor, if so check the rope and linkage. Then look at the gears in the Machine, I assume its not gearless, is that correct?
2nd Generation
2nd Generation
The encoder is on the crosshead and runs with a roller guide on the rail. it is a geared machine. Ill order an encoder tomorrow. I do have rope slip so ill be checking the sheave for wear. Seems premature to have worn ropes/sheave. .
2nd Generation
2nd Generation
It is a TKE pedestal machine with a sheave jammer installed in 2003.
the crosshead mounted encoder is the position encoder. the velocity encoder will be in the machine room, either mounted on the end of the motor, or driven by a friction wheel on the driver. at least that's the way I have always seen them.
2nd Generation
2nd Generation
i put 500lbs in the car and vibration went away. when car is empty at bottom floor loadweigher says 0 but at top floor its says 38 percent. Makes sense if it thinks the car is heavy its not going to be trying too hard to slow it down. I also found the shackles appeared twisted (according to the antispin cable) and one was touching the crosshead so i reset them back which did cause a change in the loadweigher. its a thyssen loadweigher and i spent all day trying to adjust it but I dont have an IMS fast to verify count. Going to put balance load in tomorrow and measure current/attempt to adjust loadweigher. Is it possible i have a bad transducer or loadweigher board?
2nd Generation
2nd Generation
I replaced the capacitors in the drive and that solved the problem. I believe this is a TAC50 Drive. All vibration and rope slip went away. After testing the old caps I found 2 were not charging when polarity is reversed. Now she runs great.
Nice job troubleshooting.
PHP: 8.3.36 Page Time: 0.039s Queries: 54 (0.015s) Memory: 3.1002 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 10:39:47 UTC
