I have a 400a that the buttons 4 buttons under the screen in the controller don't do anything. Normally you touch the ok, and you will get a login prompt. 1 of the cars the buttons do nothing it's like they are turned off. I have all the chips how do I turn the key pad back on? Or am I screwed?
Do you even get a click when you press them? I have seen several of these screens in everything from 321As, 330As, and TX-R5s go bad. The button presses, but there is no auditory click or feeling.
Nothing it is like they were shut off!
They cannot be shut off. Carefully pry off plastic and press little micro under neath
turn the power off and drain the capacitor for 10min then try it again
Hi,
Is this a new contract you've took on? If so I'd check that the previous Co haven't cut any tracks on pcb to render the buttons inoperable, to make the new guys look incompitent or spend money, believe me I've seen it done, and it's easy to do & prob last thing you'd look for, it's prob not the case but I'd check,
Dave
I've had the micros not work, just push on them over and over 'till they start clicking. They will start to work eventually.
If there is no click at all, then it is the micros that are bad. They seem to fail at an alarming rate for me.
So the tabs that stick out the back of the plastic buttons were broken off so nothing would hit the micros. Sabotage! Maybe? That's not cool. Thank you for your help guys, keypads work.
Your welcome
I did mention it could be, seen it to many times
Dave
PHP: 8.3.36 Page Time: 0.043s Queries: 36 (0.017s) Memory: 3.0480 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-06 06:51:16 UTC
