#8072 08/12/13 04:52 PM
reliable
reliable
does anyone have a wiring diagram for a garaventa genesis vertical hydro lift?
reliable #8074 08/12/13 08:23 PM
Is it not printed on the inside of the cover?
traction #8081 08/13/13 12:18 AM
reliable
reliable
no nothing there
reliable #8082 08/13/13 01:28 AM
What print number do you need? There should be a sticker on the duct covers inside the controller or on the cover of the controller or inside the cover of the controller. I need the schematic number and/or the wiring diagram number and the revision letter.
Johnny #8087 08/13/13 04:27 PM
reliable
reliable
Thank you in advance. I should be at the job sometime this week I will look for the numbers and post them here.
reliable #8113 08/15/13 05:20 PM
elevator lifer
elevator lifer
I have a print I need to scan it.
aquadag #8212 08/21/13 03:34 PM
reliable
reliable
aquadag thank you for letting me know you have a print. If you could scan it and email it to [email protected] I would appreciate it.
reliable #8213 08/21/13 03:36 PM
reliable
reliable
Johnny I was at the job the only number on the equipment is the ser. no. 27947
reliable #8237 08/23/13 03:42 AM
There should be a paper label inside the controller. On the older jobs, it was stuck on the wiring duct covers. On the later models, it is inside the controller. Did aquadags print work? Give me some more info and an email to send them. PLC? Garavents PDOs? Powerlocks or mechanical locks? Solenoid relays inside the controller or below the controller?
Johnny #8270 08/27/13 03:06 PM
reliable
reliable
aquadags did not send a print. I have this unit running but would like a print for future use. It has power doors,solenoid relays inside the controller.
reliable #8282 08/27/13 11:07 PM
give me an email and I send several
Johnny #8890 11/05/13 08:22 PM
I nneed a schematic for a Genesis lift also. Serial # 29650
udder #9758 02/08/14 05:54 PM
Hello,
I need an electrical schematic for Garventa Genesis (command only made ​​by relays) without electronic boards. In Portugal it is difficult to find out this information ... can you help me?
PHP: 8.3.36 Page Time: 0.032s Queries: 40 (0.010s) Memory: 3.0552 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-06 07:54:46 UTC
