#8366 09/04/13 10:21 PM
Believe I have a bad up to temp sensor.
Do i have to pump all the oil out to get to it or is there some trick.
Then I only noted a "open on rise" @ 100 degree device from Component Source.
Does this sound about right?
Any comments?
I believe you located the correct low temp thermostat.
On submersible unit, it should be bolted to the crossbar motor mount above the motor. Unless you have a lot of extra oil, it should be only a few inches below the oil line with elevator at top floor.
Thanks man
PHP: 8.3.33 Page Time: 0.018s Queries: 20 (0.004s) Memory: 3.0031 MB (Peak: 3.5924 MB) Data Comp: Off Server Time: 2026-09-21 01:50:26 UTC
