Posts: 11 |
Hello I have one problem with kone elevator. The menu of LCE controller is blocked,and i must to unlock to turn the elevator in normal mode. Can anyone help or tell me how to do it? Thanks
Posts: 5 |
Sounds like you have reached 10,000 operations and there is knx card fitted. You need a lift tech to fix
Posts: 11 |
The lift tech doesnt want to help me. You have worked with Kone lift before?
Posts: 134 |
Sounds like proprietary equipment, time to call Kone.
Posts: 11 |
There is no other solution???
Posts: 134 |
Are you an elevator tech?
Posts: 11 |
yes i am an elevator tech but not for KONE. My speciality are KLEEMANN lift (Lisa controller,klc,H32,and SERIAL controller). I would like to learning about KONE,samerlift amd others lift.
Posts: 11 |
GDB
GDB
Posts: 80 |
Buy a chip reader and reset the counter on the NVRAM
Or buy a KNX card from Kone that would be locked to that elevator
Or buy a Modu-tool with an adapter so you can reset multiple units
