#8507 09/18/13 06:02 PM
Hello
I have one problem with kone elevator.
The menu of LCE controller is blocked,and i must to unlock to turn the elevator in normal mode.
Can anyone help or tell me how to do it?
Sounds like you have reached 10,000 operations and there is knx card fitted. You need a lift tech to fix
The lift tech doesnt want to help me.
You have worked with Kone lift before?
Sounds like proprietary equipment, time to call Kone.
There is no other solution???
Are you an elevator tech?
yes i am an elevator tech but not for KONE. My speciality are KLEEMANN lift (Lisa controller,klc,H32,and SERIAL controller).
I would like to learning about KONE,samerlift amd others lift.
Can you help me???
GDB
GDB
Buy a chip reader and reset the counter on the NVRAM
Or buy a KNX card from Kone that would be locked to that elevator
Or buy a Modu-tool with an adapter so you can reset multiple units
PHP: 8.3.33 Page Time: 0.035s Queries: 32 (0.011s) Memory: 3.0343 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 06:54:12 UTC
