Hallo to all.I have connected a Yaskawa L1000A 5,5 KW with a lift equip motor type PCM145M202 with suspension 1:1 2.4KW in 11.5A 20poles and traction sheave 240mm.After a lot of settings a manage to have a not so good movement because the time that the vvvf is changing the speed from high to small the movement is stopping for a second and then is continuing to reach the leveling speed.From mechanical view the elevator is correct from VVVF view the settings are on the maximum at the PI .Have anyone to sugesτ for the settings of the VVVF?Thank you for your time
