0 members (), 92 guests, and 3 robots.
#8905 11/07/13 01:52 AM
Hello all. I need a print for a Concord Porchlift. The only paperwork on the job is a controller layout. The unit is marked Concord and the controller layout sheet is from Access industries. It looks to be about 10 - 15 years old. Any help will be appreciated. Thanks, Dan
Concord and Access Industries were two different companies. Access was bought by Thyssen and Concord was bought by Savaria. It can only be one or the other. Pictures would help identify it.
After searching the web I would tend to agree with you ABE, but the unit is marked both Concord and Porchlift and the paperwork on site is from Access Industries. I will take a picture of the unit and controller in the next couple of days. Thanks for the reply, Dan
service mechanic
service mechanic
I have alot of prints and info on several of Access Industires lifts. Send me a picture of the controller of a model number.
Here's a link to pics. http://postimg.org/gallery/ujj7xli/ The capacity tag may have been added.
From the pictures I can definitely say that is a Access lift. I think your right about somebody simply adding a Concord capacity plate. To get the prints you should be able to simply call TK Access with the serial number and they can email you the prints. If you don't have any luck with TK let me know as I am pretty sure I can find something that will match that model.
Boss
Boss
Yep...looking at that controller...its an Access Porchlift. Those plugs at the bottom give it away too. There should be some jumper plugs attached that will circumvent the belt monitors, etc.
Thanks for the reply ABE. I have not had any luck contacting Access. I have heard that TKE closed Access but I'm not certain. Any info you could supply would be great. Thanks,Dan
The problem with the unit was a belt monitor. The limit switch arm was on the other side of the actuator. With the unit at the bottom it took a while to figure it out without a print. Thankfully I had the controller layout and jumped the belt monitor input.
PHP: 8.3.36 Page Time: 0.029s Queries: 32 (0.008s) Memory: 3.0357 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-11-05 05:13:20 UTC
