#8999 11/16/13 05:25 PM
Hey guys, new to the forum so be gentle.
I'm from over the pond In the uk and having a problem with the above lift.
We had a power cut and the drive had to be replaced. Now the fault code is showing 713 block by 702. Ive been told fault code 702 is a pre charge fault. None of my gen2 pocket manuals offer any help and we haven't got nothing in our office about these controllers. Can anyone offer any help?? Thanks.
Jeffers #9000 11/16/13 09:27 PM
Ok... Found some more info out to try and help with getting some understanding of this fault code.
The drive is a ovft02b Regen Drive.
Fault code when the test tool is plugged into the drive is 713. Which states blocked by 702. So either of those codes would be great. It's on the new gen2 regen controller.
Jeffers #9001 11/16/13 10:31 PM
Proud IUEC Member
Proud IUEC Member
PM sent
Elevated #9003 11/16/13 11:16 PM
Awesome. Thanks.
Jeffers #9004 11/17/13 12:46 AM
Ok the precharge fault is where the dc bus doesn't reach it's charge within a 2 second period. Anyone know how I can rectify this?? Thanks
Jeffers #9005 11/17/13 01:20 AM
I would think either the charging circuit, supply voltage or the caps themselves.
uppo72 #9006 11/17/13 12:09 PM
That's easier said then done. I've got a ovfr1a manual but I think it's slightly different.
We have a ovfr02b drive. Does anyone have a write up on this available?? Thanks.
Jeffers #9010 11/18/13 12:12 AM
Our drive repair guys have told ya they have had it all working. We are going to change the gdcb board Incase that's causing a fault and locking the drive out. Seems a shame that I can get a ovfr02 drive write up. If anyone knows of how I can get one that would be great!
Jeffers #9020 11/19/13 12:58 AM
Yep sure but I would think undercurrent faults would be a caps issue but have had erroneous over current faults that were the same. Not on this equipment but other types of Vf's.
uppo72 #9073 11/22/13 09:46 AM
Ok, we changed the GDCB and programmed it. We are now getting fault code 726. However out manual doesn't state what this means. Can anyone share some light on this for us. Thanks.
Jeffers #9074 11/22/13 12:37 PM
Ok, found out the gdcb board doesn't pair with the controller. So I'm back to the. 702 fault. Does anyone know how or what pulls in the mx or px relays??? Thanks.
Jeffers #33250 06/15/22 02:31 PM
You ever figure out this problem, I’m dealing with it right now
Jeffers #33251 06/15/22 04:41 PM
Problem is with the AC voltage supply, the voltage threshold is 80% of the actual rectified AC line voltage.
Have you measured the AC line supply voltage and entered the correct value in M3-1 (Contract) AC Main Vrms?
/Alex
PHP: 8.3.36 Page Time: 0.620s Queries: 40 (0.418s) Memory: 3.0551 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-04 21:30:40 UTC
