#9107 11/27/13 02:29 PM
We are trying to upgrade to an Adon 2 board. There is a new adapter connection and everything else plugs in the old locations. We had intermittent problems and were upgrading. When we hooked up the new Adon 2 board as soon as we turned the car on we smoked resistor 314 !!! Is there something else we should of done are did we just get a bad board from Kone Spares?????
AC supplies for car lights/fan go through ADO boards which remains live even when lift is switched off. I would check out lights fans etc before fitting another new board
car lights/fan do not go thru the ADON board...you're probably thinking of the CCBN. As for the board smoking as soon as it was plugged in...I would check your connections. My guess is something was crossed up.
Turned out to be just a bad board form Kone Spares. We installed the next board the same way and set it up no problems. Thanks guys.
Car light supply goes through ADO boards on Monospace MkI models.
I have had to replace a few myself after accidently grounding live parts when trying to be clever and changing car light tubes with the power on.
PHP: 8.3.33 Page Time: 0.025s Queries: 24 (0.006s) Memory: 3.0151 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-20 22:19:13 UTC
