0 members (), 45 guests, and 3 robots.
Page 2 of 2 1 2
Hi there,
The car gate switch is not part of a 0021 fault - stop switch, governor, car top box, safety gear etc shown as 0021 fault
I'll have to re-check what I sent , I typed so fast I may have not realized . I ment to say usually it's the gate wires that have broke on me . Thanks for the heads up .
Hi,
Does this happen with a empty car or with load?
Hi
I guess it's only happen with an empty car - if so, take two plates from to counter weight out, put them on the car top, adjust the load weighing (gain and off set), and give it a go.
Cheers
Probably time to get Kone tech in to sort things out for you
Had the same exact problem. Ended up being tight counterweight rails at the top and in need of some lube. Lubed rails and opened up DBG a little and Voila!
Page 2 of 2 1 2
PHP: 8.3.36 Page Time: 0.036s Queries: 26 (0.010s) Memory: 3.0407 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-11-06 17:29:52 UTC
