0 members (), 29 guests, and 1 robot.
#9385 01/03/14 03:03 AM
I am looking for the I/O list for Otis MRQ Spec 60. Security car reader input for the 7th floor is one of the ones I am having trouble with and would like to check but I don't know the input #. Any help would be great.
poons #9398 01/03/14 07:32 PM
I have checked the security input for the 7th floor and it is fine. The problem I am having is the car will run to all other floors but the 7th landing. Total 8 landings in building. The 7th floor call buttons only light when it is pressed and will not latch. The 7th call pc boards have been checked and O/K (dual cop's). I can send the car to the 7th floor with the service tool.
poons #9402 01/04/14 03:09 AM
Poons does this type of lift have button modules that are specifically id'd for a certain level so you need to replace them with a specific part or are they universal going into a car module which is then decoded to tell what level has been pressed. The reason I ask this is if they are universal then swap the module with another level(not 7) and test it. If it works at another level, but with the module you just swapped it still doesn't then the car module is faulty. You can even do this if the are only programed for a certain level(fixed hexadecimal addressed button module wired in a serial data loop). Swap it out as I said and if it then does latch for the 7 button then the wiring to the car module either internal or external is faulty.
uppo72 #9404 01/04/14 03:02 PM
The button modules are universal going into a car module which is then decoded to tell what level has been pressed which we swapped to another level and it didn't work, we also changed the car module that each floor goes into didn't help. I am going to see on Monday if the floor will work on phase 2 to confirm if it is on security and maybe the I/o is misaddressed for the 7th landing. I will also recheck the car module wiring.
poons #9415 01/05/14 03:14 AM
Poons I would say if you have proved that a) an individual button assembly works in another position or another works(or the fault stays the same) in the same position as the faulty button then that is ok and b) that you have proved that the car module is ok by replacing it then its most likely that the main controller interface is where the problem lies. This is probably either a software issue(for some reason has turned of the level or even put a secured link on it) or that a hardware issue has happened( such as a opto coupler or the like). Either way I would get another board to at least prove this.
uppo72 #9422 01/05/14 01:45 PM
Are you referring to the ring car board
poons #9423 01/05/14 02:48 PM
Did you clear your PF ram, A similar thing happens to some of our MRQ's. Never just one floor though.
We will clear the PF Ram tomorrow, no faults on OCSS and the RCB was just repaired by unitec. When the 7th floor car call is pressed we can see the 7th floor I/o for the light and button go high and low on the service tool. We picked this unit up from a competitor and half of the I/o's on the I/o sheet were changed.
poons #9428 01/06/14 03:08 AM
poons since you see the input change it suggests the hardware is ok but isn't latching. It may be a security setting.
uppo72 #9450 01/08/14 02:34 PM
It will go to the 7th landing on phase 2. We can see the I/o change for the 7th landing on the service tool when the 7th car call is pushed. All card reader inputs CRI are all 0.
poons #9467 01/09/14 12:10 PM
We cleared the ram and works fine now.
Thanks for the help.
poons #9472 01/09/14 08:19 PM
Another problem showed up today, on automatic when the elevator goes to the lowest landing the doors stay opened until a car call is entered. Works fine on all other floors. If a car call is pushed once the doors are opened they will close and the car will go to the floor. If the doors stay opened for a longer time and a car call is pushed the doors will close and the nudging buzzer will sound. Nothing in the door detector. Hope this makes sense.
poons #9476 01/09/14 11:14 PM
I would check the homing function to see if there is a door sub section included but the system sounds a little flighty.
uppo72 #9477 01/09/14 11:34 PM
The elevator doesn't go to the lowest landing automatically and park. When it is called/sent to the lowest landing the doors remain open until a car call is placed.
poons #9480 01/10/14 02:49 AM
door open limit, o6 on a QL, problem due to the first floor HW door? i.e heavy door or worn relating? does it ever go into DTO mode?
Agree GP if this is just a normal call and the doors are staying open, then go onto nudge then yes I would check the DOL. Strange that this is only at this floor, so check the action of the landing doors/tracks. Do/are they fully open?
uppo72 #9486 01/10/14 03:25 PM
This happens at both terminal floors. DOL goes high at these floors. After it sits at a terminal landing it will close on DCP.
poons #33872 09/16/22 03:20 AM
Lev Offline
Dear All,
Anyone can send me the schematic of spec 60. Thanjs in advance
Regards
Levo
poons #33918 09/21/22 03:00 PM
Lev Offline
Dear all,
I have attached a screenshot with marking. Can anyone tell me the meaning of it
Thanks in advance
Levo
PHP: 8.3.33 Page Time: 0.028s Queries: 53 (0.009s) Memory: 3.0859 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 02:32:23 UTC
