#9651 01/27/14 04:33 AM
troubleshooter1
troubleshooter1
I hav a Ln card that i believe is bad., the power light is on, but the STAT led is not blinking. the book has 3 different descriptions for various blinking rates of the stat led, but nothing about no stat led, does this indicate a bad card? the card was working, but when i turned off the power and back on again, the light does not come on.
If you delete that node under Advanced Lon ( you must have the LonsTalk adapter) , are you able to find it again ie replace node utility?
Smitty #9657 01/28/14 01:13 AM
You getting any 1085? Faults
Postal #9662 01/28/14 05:31 AM
troubleshooter1
troubleshooter1
well i found out what happened, seems that the r11 and r12 resistors both opened up, which opened the 24 volt feed to the 5 volt regulator chip. since these were both 2.2 ohm resistors in parallel, i jumped them out and all is well. using the card for a test rig, so it is not going to be a problem leaving the resistors jumped while i play around with my test set up. my wife now tells me the cat was climbing on my desk, maybe the damn cat did it. ha ha
PHP: 8.3.33 Page Time: 0.023s Queries: 22 (0.006s) Memory: 3.0114 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-20 23:07:10 UTC
