#9727 02/05/14 12:13 AM
Dover TIII Tacho
Does any one have or know where to get one of these tachs in the US. I've found them on websites in the UK but looking for one locally. Thanks....
6 Comments
http://www.directindustry.com/prod/zodiac-actuation-systems/dc-tachogenerators-31913-214515.html
Have you looked here?
How about vertical express/component source ?
Postal #9729 02/05/14 01:46 AM
Postal #9730 02/05/14 01:49 AM
Postal #9757 02/08/14 05:41 PM
Thanks for the suggestions. Unfortunately, no one had this particular tach. I had to order one from the UK. If anyone is doing a Mod on TIIIs, you may want to hold on to the tachs since they are hard to find.
I'm super suprised you couldn't order a tach from baldor that matched your old tachs characteristics
Huh
Good luck
Postal #9765 02/09/14 03:13 AM
I was very surprised myself, this tach is very special with an output of 20 volts per 1000 rpm at .2 amp and the TIII is very sensitive to receiving the correct voltage. I tried using another tach that was close and modifying the voltage though voltage dividers but I couldn't get it to work properly. There was a possibility to do a special build but the lead time was too long so I had to do the alternative. Now I know for the future. What's really bad is I've probably thrown away at least 6 TIII tachs from mods in the past 5 years.
PHP: 8.3.33 Page Time: 0.043s Queries: 33 (0.027s) Memory: 3.0329 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 00:49:17 UTC
