0 members (), 27 guests, and 3 robots.
#545 06/29/10 08:43 PM
Is there a way of reseting the lift on the service tool. lift goes into fault when runs to level, but when i reset lift an plug service tool into lcb 11 board the lift will run fine when i plug out service tool and call lift to floor it runs to floor but wont accept any other calls.
Can any one help me
Mick
MichaelJH #570 07/15/10 11:30 AM
4 Offline
Sometimes the LCB II logs certain faults in the eprom and shuts down the lift and you have to do more than reset it. Have a look at the lift status for a 'flashing fault' such as DBP or DCS. This could be because the lift has tried 2 correction runs in a row or because the door sequence has not completed correctly, and won't allow normal operation until it has. Sometimes you will need to put the car on inspection to clear it.
401PPT #575 07/16/10 05:46 AM
Thanks for your reply 401PPT. I tried to put lift into inspection to clear flashing fault, you say that the door sequence may not have been completed, i have 2 levels, level 1 has straigth through on either side of lift both are accorrdian manual doors, level 2 has one accorrdian door all doors only have locking and door contacts,
you said in your last mail that i should put the lift into inspection and then clear fault? can you explain how i would do this
thanks again
MichaelJH #576 07/16/10 11:27 AM
4 Offline
Hmm i've never had them with manual accordian doors before, only centre opening auto doors. In this case the doors do an open and close check sequence before the car can operate otherwise it shuts down and only drives on inspection.
What i mean is just flick the car on inspection and back to normal and sometimes it clears certain flashing faults. If you can't access the car top or there is no ero operation from the controller, you can remove the wire and put it back in the terminal strip (2c4 or 2H4 something like that, check the print) and it will also reset it this way.
401PPT #577 07/16/10 12:13 PM
if it runs on insp and NOT auto depending on the age the PF ram (power failure RAM) might need clearing (have been caught on that one before). Cant remember off the top of my head but think its 1-5 on the menus. while your at it also clear the SAC ram as well.
Hi
I was talking to you about a fault i am having with an otis mcs 120.
I try a selftest results are PR+ EE+ RA+ RS 04Ar000 and if i press go on ( on service tool) RS 018Ar000 and press it again i get RS 032Ar000 an press go on again RS-. Can you example to me is this a fault.
I also checked the Events menu these are the faults below
0100 OpMode NAV
c002 t25929 p**
0104 OpMode DCP
c008 t13644 p01
0201 Correct.Run
c002 t41747 p**
0204 TCI/ERO on
c024 t00029 p00
0300 DBP: dfc_SE
c001 t05689 p01
Can you tell is one of these events the problem with this lift i have no refenece manual on this lift and this is the first otis lift i have had to work on?
Thanks Mick
MichaelJH #590 07/28/10 11:56 AM
the first value c is how many times the fault has occured since last reset....the t is the time since the last fault and the p is the position. The only thing you list which might be something to look at is the TCI/ERO which is top of car inspection/emergency rescue operation in other words it was put on hand control 24 times and the last was 29 mins earlier. change the RS4 (or 5 or 14) board as sometimes play up I cant remember off the top of my head which one it is but im sure someone will know (it should be on the drawing anyway). you dont really have to concern yourself about selftesting the system dosent tell you all that much .
PHP: 8.3.33 Page Time: 0.040s Queries: 28 (0.009s) Memory: 3.0266 MB (Peak: 3.5898 MB) Data Comp: Off Server Time: 2026-09-21 14:33:28 UTC
