#10009 03/05/14 06:23 PM
Service Manager
Service Manager
hey ya. I have a unit that cycles the doors whenever the hell it feels like it. Already replaced the door board. It doesn't do it frequently enough for me to think it is a lock or gate issue. This is a 2 stop hydro and it does it on both floors. Any ideas?
bk2fla #10010 03/05/14 07:28 PM
I'd check the programming, also make sure when you replaced the board that all the plastic clips have been pushed all the way through the new board and secured. I'd also check the pick up assys for proper adjustment and door contacts. Check and see if your dcl is leaving enough clearance for the pick up rollers when the door is relaxed.
bayblue #10011 03/05/14 09:55 PM
Shootintrouble
Shootintrouble
A couple things. Car door is drifting open off DCL and/or clipping p/u roller as it's drifting open. Another possibility you have another floor h/w door intl'k contact that is interm. opening when car is away from that floor. Remember doors will cycle with open door lock any floor or gate or no DCL.
sccjr #10015 03/07/14 03:46 AM
Yup your limits aren't set correctly, if your doors drift while they are on the limit its not right. You move a limit you gotta do a door scan. No updated door scan problem will never go away.
Common on two speed side slide.
sbrmilitia #10016 03/07/14 03:47 AM
Seems like a problem a service manager would have...jk
sbrmilitia #10018 03/07/14 09:44 PM
Boa Offline
Also check the magnet holders. I've seen them crack allowing magnet to move.
sbrmilitia #10029 03/10/14 04:29 PM
Service Manager
Service Manager
that's just the tip of the iceberg buddy!!! lol
bk2fla #10030 03/10/14 04:29 PM
Service Manager
Service Manager
thanks for all the threads!!!
bk2fla #10036 03/10/14 05:52 PM
mjm Offline
these units will cycle the doors when ever one of the following is opened. Hw lock, DCL, or Gate sw. DR. Note, the damn stroke adjustment on the door operator can allow the car door to "drift" off the dcl sensor. Then the doors will cycle. or HW door lock. The stroke adjustment on the hd85 operator,well, all Dover operators, needs to be strong enough to hold the door shut when there is no power on it.
mjm #10037 03/10/14 05:52 PM
mjm Offline
especially if it is a side opening. they are notorious
mjm #10038 03/10/14 05:54 PM
mjm Offline
also, the doors will not power up on viscosity control and sometimes the doors can drift as well.
PHP: 8.3.36 Page Time: 0.027s Queries: 36 (0.008s) Memory: 3.0481 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 21:12:18 UTC
