0 members (), 24 guests, and 1 robot.
#10105 03/16/14 05:39 AM
I have to install LCEKNX board of KONE in LCECPUnc board for the KONE elevator but i have no idea about its connection therefore can anybody provide me any technical information about its installation.
Just plug it into CPU. No need to do anything else.
Hi
Are you putting it for any reason or are you just wanting to access the menu, as the last post says just plug it in and you have access.
Dave
Actually i have to get access on its menu but when i plugin this KNX card on my CPU that is LCECPUnc than nothing happened. This KNX board is new therefore do you have any solution?
Considering the very basic information you request I would suggest you give up messing around with equipment you clearly have little knowledge of and leave it to someone who knows what they are doing
Are you sure you've got a KNX & not a VOI it wouldn't be the first time someone made that mistake and a costly one at that, it will say on the front just under the transformer sticking through the top??
Z
Z Offline
Older LCECPU�s CPU software versions 3.xx � 5.xx
Solution 1 Remove NV Ram pack whilst elevator still powered up and replace with new clean NV Ram.
This solution works but it could prove to be dangerous removing Ram while power still on to elevator.
Solution 2. Clear run counter and reset to zero
Location of code
0FAE � 0FAF Clear & insert 0000
0FD6 � 0FD7 Clear & insert 0000
0FD8 � 0FD9 Clear & insert 0000
For this You need a NVRAM DS1230Y-70, RAM editor, HEX editor and computer
GDB
GDB
Or you can buy a modu-tool and reset as many as you like, not cheap at �2500.00
there are also tools on the market for about �700.00 that will give you 200 resets.
GDB
GDB
Out of interest how much do KONE charge for a KNX in the States?
PHP: 8.3.33 Page Time: 0.055s Queries: 32 (0.032s) Memory: 3.0344 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 18:34:53 UTC
