Posts40,945
#10323 04/09/14 09:34 PM
Hello all. I have a Cheney Wheelchair lift that is stuck on safties. I tried manually running it up, but no change. It only travels about 24 inches so there is not alot of access space under the unit. Can anyone point me in the right direction? Thanks , Dan
Did the lift move at all when you tried to manually run it up?
I have two of these units. You can PM me or try email Jim at [email protected].
You will need to align the governor pin and lever arm in order to set the cam.
jhk is correct. It can be a real pain in the a$$ and definitely requires 2 people to reset in my experience.
Yes it moved up about 6 inches.
PHP: 8.3.33 Page Time: 0.042s Queries: 24 (0.022s) Memory: 3.0146 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-09-21 19:18:32 UTC
