robot. |
Schindler Door Operator
Just picked up this Schindler car and the door opens and closes very slowly. We suspect it probably has a bad encoder. Is there anyway to adjust or re-learn without the tool? Any other ideas why it would be running so slow? Thanks for any help!!
Posts: 563 |
Have you checked the pcb for the PDO and if it has any switches/resets? Normally when I want to do a relearn I switch off the power to the operator, open the doors to half way open, then switch the power back on. Normally that induces a relearn of the operator.
Posts: 404 |
I haven't tried a power down and setting the doors half way open. I'll try that to see what happens. Thanks for the tip.
Posts: 422 |
Good Morning, If you know the Model I probably have a manual for it. Jim [email protected]
Posts: 909 |
Looks like a QKS-16(VF). What unit is it on? 321a, 330a, 400a Is there a chance the previous service mechanic changed the potentiometers?
Posts: 404 |
This one is on a 330A. Where are the potentiometers? Are they in the box that looks like a power supply?
Posts: 909 |
Sorry Admin, I'm going off of memory here. The board was usually in the car station. Do you have a print and/or a manual? I'll try and stop at one of our customers on my way home.
