#10547 05/02/14 01:22 AM
Q
Q Offline
Intermittently Im getting a 109 fault (position loss) with extra info of 3065. None of the material I have gives what 3065 means. This only happens running up from 1 to 2 (2 stop MRL. What a mess!). The fault never happens running down. I thought it may have to do with the sequence of 77U and 77N but when it happens I don't notice anything different from other runs. It may happen every 20-30 trips.
Can anyone help with what 3065 means?
Q10559 #10986 06/11/14 04:41 PM
Sub code 3065 is a fault code used with KDL drives.
It relates to 77U fault or encoder fault. Check also that encoder cable is separated from motor cables etc by >100mm. Check 77 probes and connectors
Could just be a dodgy probe.
koneisland #10990 06/11/14 08:05 PM
Q
Q Offline
Thanks for the reply. A hoistway learn corrected and hasn't come back in since 5/2.
PHP: 8.3.33 Page Time: 0.020s Queries: 20 (0.004s) Memory: 3.0035 MB (Peak: 3.5924 MB) Data Comp: Off Server Time: 2026-09-21 05:24:13 UTC
