Posts: 24 |
Hello,
I need your urgently support. We changed bearings of machine type MX10, but now we do not have adjusment elevator. It is show error 117, 113 and 0083. We enters all parameters and "training" elevators, but nothing. I understand that when we made repair machine we must change resover, but I do not sure this is truth. Do you know? Can you help us?
Posts: 909 |
Hello Supervisor, Please do not take offense, I'm just trying to understand who is asking for our help? Are you the building supervisor? Are you in the US?
2nd Generation
2nd Generation
Posts: 51 |
You changed machine bearings on an mx10???? A bad drive or connection can cause a vibration similar to a bearing, , what kind of drive is it? An mx10 with a resolver?
Posts: 24 |
Jkh "the supervisor" is juct nickname
rollaway-up - I am sure that the elevator has a problem with bearings. Yes machine has resolver. We change bearings and installed in the shaft. The first we have a problem with running on the elevator. When we push button for run-down, the elevator has run-up. Wr clear all parameters and enters again. And when we "training" eleator he run down and next run up and stop. We think that problem may be in resover, but wr do not sure.
2nd Generation
2nd Generation
Posts: 51 |
Sounds like the motor leads need to be swapped. The tach signals must match the governor encoder. Is this an ecodisc? Are you certain is resolver and not tach?
2nd Generation
2nd Generation
Posts: 51 |
Posts: 24 |
We checked swapped and taho, but we have a problem yet.
Posts: 116 |
That's the second time someone asked you where your from . How about a third ? Where are you from?....... And what type of drive . V3f25 ?
Posts: 909 |
TS, I'm having trouble following your request. Could we start over? 1) please describe the original trouble you were experiencing. What error codes were you getting? 2) prior to replacing the bearings, did you change any parameters? 3) after you replaced the bearings. What steps did you take to re-commission the elevator back into service? 4) what country was this elevator installed? I ask because I'm under the impression the MX10 was for the US market.
The more information (details) you provide the better.
Posts: 451 |
This may be a stupid question but what on earth is a resover?
Posts: 32 |
I have changed bearings on some mx machines before with no problems although I did have a step by step manual from kone elevator along with a tool kit. I also set up resolver from scratch and checked load weighing. Also check your connection on tac and resolver.
Posts: 24 |
I am from Bulgaria. We checked connection on tac, but nothing. I think that if we to have check connection, we to have open machine.
JKH - the machine has very hard noise and we were sure that problem is bearings and when the service opened machine this was right. Next we put the machine with new bearings, but cannot training elevator.
Posts: 24 |
Sorry for confusion, but the situation is very critical for us. we chech all parameters and boards and we think that problem is resolver and machine. Do you have instruction or other docunentation and advice?
2nd Generation
2nd Generation
Posts: 51 |
The resolver keeps absolute position of the shaft in relation to the magnets so the drive can give the necessary output.
Check to make sure LEDS TPOL and RPOL are illuminated when driving up, if not it could be polarity of either.
I still think your motor leads are reversed, youll need to get the car to go up when you run up on inspect, than confirm tach/resolver polarity with the leds.
Posts: 24 |
Thank you rollaway-up, but we checked this without result. Our colleagues tell me that the machine MX10 is not repair and only must be change. I am not sure for this.
Posts: 24 |
The staeps we did after we installed the machine :
I.BEFORE we install the ropes : 1.Unplug the cable of the tacho (in the drive ) and check that the value of 6_10 is the same as the one in the drive (-2.704v) - done with no problems 2Unplug the cable of the tacho (in the drive) and switch the jumper S5 (next to the tacho) on 1-2 (test) and manualy rotating the machice to make sure we have correct signal on RPOL - done with no problems 3Plug the cable of the tacho (in the drive) and switch the jumper S5 (next to the tacho) on 2-3(normal) and manualy rotating the machine to make sure we have correct signal on TPOL - done with no problems 4Star menu 6-70 (adjusting resolver angle) and follow the beeping signal (4 beeps - up until it stops and 2 beeps down until stops) until the beeping signal stops and the angle is adjusted and check the angle in menu 6_61 - done with no problems 5We instal the ropes
II AFTER the ropes are installed :
1Start menu 6_70 again and follow the signal until the angle is adjusting and check the angle in the menu 6_61 - we had no problems with that 2.We adjusted LWD - we had no problems with that - now the elevator works correctly on both direction on inspection mode 3We check the speed on the inspection mode in 0.3 - menu 6_21 4We move the car just bellow bottom floor (61N signal is off - 61U,30 and 77N are on) - and start the menu 5_2 - 1(to start learning mode) - The car starts learing mode without problem and start moving up 5After reaching topmost floor the elevator stops - at this point this means the the elevator is ready for normal mode - here we have a problem - At this point the menu shows error 0109 and 0083 and if we leaved still on normal the elevator start to releveling on the floor (61N, 30 and 61U signals on and 77U on).After this point the elevator lost possition and cannot start
The only way to move it is on inspection and do again step 4..We made alot of tests - with magnets, with 61N,61U,30 ,77U and 77N signals, with tacho, we even switch the Drive board and installed it on the other elevator(and the board works correctly on the other elevator) - and we still get the same error once the elevator finish learning mode - 0109 and 0083
2nd Generation
2nd Generation
Posts: 51 |
Ok sounds like you're doing the right things, ill have to think some more.
Posts: 24 |
Posts: 909 |
TS, Are you using a written shaft learn procedure from Kone?
I believe 0083 & 0109 error codes indicate your elevator is getting lost during your shaft learn. This could be related to how you are performing the shaft learn.
It's the 113 & 117 error codes that are jumping out at me. I'm not sure but I think they are related to the sequence of your shaft way switches are made.
This has been sitting in the back of my mind since your first post. Is the drive a Yaskawa G5?
Posts: 5 |
Sounds like not accepting learn check motor terminals as I have had that cause not to learn shaft properly
