0 members (), 95 guests, and 2 robots.
Page 2 of 3 1 2 3
greg70 we check motor terminalas any times.
JKH the drive is V3F18
We almost sure that problem in is resolver, but when I open machine again we see resolver with white magnetic. In the site of Kone magnetic with black magnetis. I am not sure what is differnt.
Do you know number part or differnt of magnetics?
I would call kone and have them fix it for you and ask what was wrong. We fix elevators for other companies and vice versa when ever it's a high priority job. Just fixed a st for schindler last week and put in a digital drive in a st for otis. We all need help sometime especially me.
unfortunetly the local Kone cannot to help us and this is not first case
Why wont they help???...is there some previous problems that you have had with them..usually a company will jump at the chance to make some money!!!
I do not know why, but whenever we call for service or parts thereof have not received any response or refused.
Their only problem is that we're competition. We have not refused assistance.
Unfortunetly we change resolver,but nothing.
we see only error 117. How we can cleaning absolute?
GDB
GDB
Think i had a nightmare like this once.
GDB
GDB
117 drive setup fault-Reset setup from drive 6-16>4
Bad comm's cable LCE to Drive?? Incorrect Parameters in drive??
This job sounds like a living hell!!!
Unfortunatly - yes.
thank you
GDB
GDB
I meant check your comm's cable and tweak your parameters.
Are you getting any sub codes?
We will check cable again.
We see only error 117, but the elevator hasn't menu 6-16
GDB
GDB
V3f 18 so i am thinking the elevator is about 10 years old?
GDB
GDB
Do you get (-----) on the display when the elevator reaches the top floor on a shaft learn?
What software version do you have on LCE?
Have you tried changing the motor type in the parameters to something different, to say MX 20 and then changing back to your motor for example MX 10 as this ill load preset parameters into your drive. this is use full if you have been changing parameters and need to start over.
Also may be worth checking tacho filter parameters and that 77 switches are not getting a false signal during set up, from something like a guide bolt.
Do you get (-----) on the display when the elevator reaches the top floor on a shaft learn? - YES
What software version do you have on LCE? - I am not sure
Also may be worth checking tacho filter parameters and that 77 switches are not getting a false signal during set up, from something like a guide bolt - WE checked.
The elevators work in group with two same elevators.
GDB
GDB
Ok so i am going to presume that you have checked the limits are not to close at the top floor etc etc
And that you have done the resolver auto tune 6_70
Are you storing the parameters using initial settings 6_98 then cycling the power after setting resolver angle to 0 ?
And 6_99 to store in permanent memory?
Try changing the motor type and then back to your required type and the go through the parameters and store.
When we mafe parameters got angel mashina of 0 and next we back of previuse number. The elevator "want" we adjustmebt the loading devise. This is normal?
We solve the problem. Thank you for your advice.
And the problem was,,,and how did you fix it,,,,this could be interesting..
GDB
GDB
C'mon Supervisor don't leave us hanging..
Page 2 of 3 1 2 3
PHP: 8.3.36 Page Time: 0.045s Queries: 55 (0.015s) Memory: 3.1164 MB (Peak: 3.5904 MB) Data Comp: Off Server Time: 2026-11-05 11:33:04 UTC
