#10852 05/28/14 01:04 PM
JWB
We just finished installing a ThyssenKrupp I-2 valve upgrade on an older Dover elevator. The elevator runs fine with the new valve but it has developed a noise that sounds like cavitation. The oil level is fine and the elevator operates correctly. My only problem is this loud noise. Any ideas?
Just the valve? Not the pump unit as well? I have had some pumps with some noise before, but never a valve issue. There is a softener we use from CAT that is for hydraulic systems, helps with packings and smoothes out twinposts that sometimes have dry seals that cause some chatter.
Keep us updated, I am a new install adjuster, work on 5-7 new I-2's a week or so.
Does this noise only operate in the up direction when the pump is going? Try to separate which valve may be oscillating or radiating noise. Is this a standard valve system?
Rags, packaging material or other crap could be starving the pump input. If its a dry pump unit, you may have have had the inlet hose break apart inside of itself creating a "flap" that starves the pump.
By chance is the valve from Linden if so return it there gunk.
Gunk?
When does it make the noise... during acceleration, high speed, transition, and/or leveling? Does it only growl at upper landings when the oil level in the tank is lower?
E3 11 is correct we have had several cases of clogged filter screens in the pump unit. Drain the tank check for foreign objects are collapsed hoses. Good luck
You can always pull the up leveling adjuster and see if there is anything in it. Really easy and quick. If you find shavings etc you can expect to see more inside the valve. Count the threads!
Rode one of them Linden valves once
Prettiest accel and decel I've seen yet
But it hammered the Crap out of you right smack
I'm the middle of high speed plateau
PHP: 8.3.33 Page Time: 0.050s Queries: 34 (0.024s) Memory: 3.0427 MB (Peak: 3.5929 MB) Data Comp: Off Server Time: 2026-09-21 04:31:07 UTC
