#10961 06/09/14 04:02 PM
Car generates a 2815 fault. During the cycle test it drops EES C and the DGR ((doorand gate)relay before allowing a run. The EES and C relays function fine and drop then repick as they should. The output CIO never toggles thus allowing DGR to stay picked.
I have been able to toggle the CIO output via the tool. The relays are in good shape and we did try a different EES relay with the same results.
Smitty #10962 06/09/14 04:50 PM
Sorry a quick correction.
The door gate relay is actually GDS.
This problem occurs on inspect as well as normal. The route mechanic did swap the LCMLB with a spare but the problem remained.
Smitty #10967 06/10/14 01:43 AM
Len Offline
Do you know if this has the old mlb board..or has it been upgraded with the remote FUJI relays?
Len #10969 06/10/14 04:09 AM
These cars have the remote relays.
Smitty #10982 06/11/14 03:32 PM
The problem turned out to be a faulty LCR contact. Another example of an error code leading one in the wrong direction.
PHP: 8.3.36 Page Time: 0.026s Queries: 24 (0.007s) Memory: 3.0160 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-04 21:31:30 UTC
