#11164 07/01/14 12:48 AM
BSP
BSP
Hey bros of iuec. I have a 330A that will always get a 20 error with extra info 67.(possible PCT issue)always happens at the 3rd floor. I have changed the landing system , CRIP, and CIO board. CAP drain. Also made sure my UL Spring wasn't broken. Any body have anything on this?
MBKE
You may want to check your leveling. I usually set it for 5 to 6 seconds! If the time is too great it can trip those errors.
jkh #11235 07/06/14 02:31 AM
is 3rd floor the top landing? if so,schindler may want to park the car above the floor by an inch on a relevel to reduce the number of times it relevels. otis does this and it means the up normal is set to low. the 20 fault with a 67 is relevel stall for more than 7 seconds. try cracking manual lowering while parked at that floor and see if it faults.
PHP: 8.3.36 Page Time: 0.032s Queries: 20 (0.013s) Memory: 3.0027 MB (Peak: 3.5904 MB) Data Comp: Off Server Time: 2026-11-06 06:02:40 UTC
