Posts: 104 |
Hi Guys: I have this sigma controller fault, but do not have the manual. The screen show: ACD=03 07FL 042% E085-91 000000 S 1100110100000010 Anybody know what it is? and how to reset it? Also, anybody have a sigma controller manual? I would like to Purchase from him? my email is [email protected]Thanks, Ken
General Manager
General Manager
Posts: 10 |
ACD 03 = out of service 07FL = the elevator is in the 7 floor 042% = is the value of the load weight inside the cab E085 = check the relay R5SC auxiliar contacts stay on
I'm a certified LG/Sigma elevator technician, if you have any other problem feel free to contact.
Posts: 104 |
Thanks, I will check it out tomorrow.
Posts: 104 |
Hi zab R5SC is not picking up but the safety circuit ring out good? I have 50 vdc all the way to pit-2 terminal? On DOR-210 BOARD which terminal is for R5SC relay? Thanks, Ken
Posts: 81 |
Hello, maybe you need to make a learn, I have 6 units a there's no problems. How many floors does the building have?
Posts: 104 |
7 stops and no manual Can anybody sell me a copy of the manual? Thanks, Ken
Posts: 81 |
Ken, send me your email . I have the information you need.
Posts: 104 |
Posts: 81 |
Ok Ken , I send you the information.
Posts: 104 |
Thanks, I will check it out tomorrow. Ken
Posts: 104 |
Update: First, Thank You guys for all the help!
Finally, get the elevator going. Problem is DOR-220 board OUT-1 connector (Bad Connection). Even fix the connection, the fault E085 still stay and R5SC relay still not picking up. Need to turn off mainline, set DOC-220 board SW5 dip switch 4 on, then turn on mainline, then the R5SC relay pickup and the fault E085 go away. Don't know it is the right thing to do. Still looking for a manual. One thing I do learn from this call is. It is close to impossible to troubleshoot this controller without the right print and manual, most of all you guys help! Ken :-)
Posts: 7 |
Hi All I have Sigma control , any one can help me I do not have the manual , how can I use DOA-100 ??? Thanks
Posts: 7 |
Hi Cucuvator I do appreciate if you can send me an copy of user manual DOA-100 (in English) my email : [email protected]
Posts: 81 |
Hey, tell the problem, I try to find the best answer, I don't have the manual in Pdf.
elevator parts
elevator parts
Posts: 7 |
have you solved this problem already? if still no, please let me know
[url=http://hselevator.en.alibaba.com
Posts: 642 Likes: 5
Posts: 642 Likes: 5 |
Not really off topic, but I think it's great to see the forum reaching across the globe. Experience from distant places from "home" blazing across the internet bringing help to whomever needs it on a variety of equipment. Thanks everyone for your input over the years, it great to see!
Posts: 2 |
E85 this mean R5SC always on , you can solve by checking 48 volt , and input output buffer of R5SC , some time feed back ground appear as 48 volt , ground source from main boared DOC ..
Posts: 10 |
Hi My lift is showing error 55-94 it bombs out as soon as relay C1ST and C2ST attempt to pull in. it does not move at all.
Posts: 3 |
Hi I have a Sigma Si210 having an error E095-91 wich randomly appears. making some research i have found is a r5sx related failure, still need the manuals, does somebody have these manuals in PDF?
Posts: 10 |
Dear aLL; we have 2 sigma elevators, one is not working for so long,we are trying to solve the problem, it gives us so many error codes( E171-90 000 00s,E053-91, E032-91), and we don't have the manual, I am wondering if you guys can help us. I am also looking for some one who can travel to addis ababa, ethiopia to fix our elevator, one with a good knowledge of fixing elevator best regards Fikadu +251-911-175303
