#12265 10/08/14 05:02 PM
hex
I understand the brakes on Dover GD105 or B105 machines are notorious. They were used on PDQ and MP1 vintages. I am looking for information on setup/concerns so that I don't have a car hit the roof.
I would appreciate any help you can give.
hex #12373 10/17/14 07:12 PM
Liscensed Journeyman
There are retrofit kits available from Vertex. Highly suggest that you do this. Only if you can pull the armature pin out of the plate. That pin can hang-up with brake open.
Part No. Print No. Description
9815831 200GN5
Solenoid, Brake, Retrofit Kit, GD-1 Dual
Solenoid, W/ Armatures, Sleeves &
Nameplate, for 130 VDC 799AB1 Solenoid
9815820 200GN4
Solenoid, Brake, Retrofit Kit, GD-0, Dual
Solenoid, W/ Armatures, Sleeves,
Cushions & Nameplate, for 779AC1
Solenoid
Solenoid
9815806 200GN2
Solenoid, Brake, Retrofit Kit, Geared Single
Solenoid, W/ Armature, Sleeve, Plates,
Dustcover & Nameplate, for 140 VDC
126689 Solenoid
9815790 200GN1
Dustcover & Nameplate, for 220 VDC
126688 Solenoid
9815818 200GN3
Solenoid, Brake, Retrofit Kit, GD-1, Single
799AE1 Solenoid
hex
Thanks for the info JustWolf.
PHP: 8.3.36 Page Time: 0.023s Queries: 20 (0.007s) Memory: 3.0047 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-05 03:53:25 UTC
