Posts40,945
I cannot get HST relay to drop out and cancel the hall calls. This is a duplex and it is approx. 30 years old. The situation is as follows: The only way the the hall calls will cancel on the one car is if the second car is at the same landing. I have checked and changed a number of floor bars on the selector and still no luck. HST Relay is set / reset coil and for information purposes only it is a 222 cy1 Any suggestions would be greatly appreciated . Thanks in advance.
The cy1 isnt a set/reset coil....only has one set of windings....would have to be a cx1 or cz1 coil for that...make sure you have the correct coil in the relay .
PHP: 8.3.33 Page Time: 0.021s Queries: 18 (0.004s) Memory: 2.9983 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-09-21 19:14:32 UTC
