#12550 10/31/14 10:29 PM
I have a kone E-5000 that will run for a day or so and then shut down - Not a hard fault so it just keys back up. The fault is Safety String Fault. The Tool says to check continuity between Annuciator boards and check pins and connections and I have done this and all is good. Just reaching out to see if anyone else has had this issue. Also says to check a few relays on cpu and have done this also.I went as far as changing both Annuciator Boards to no avail.
Romo #12551 10/31/14 11:30 PM
are you flashing a fault code?
john jay #12552 11/01/14 02:12 AM
yes. 66 on the read out in controller and the kone tool says its "safety string fault"
Romo #12554 11/01/14 01:09 PM
The only thing I can recall about a 66 had to do with a brake problem. But since I worked on 3000's and 5000's I don't know which one that pertains to. You may want to check your brake voltage just to be sure. I think it was around 160vdc. also the normal brake ohmic value was in the 350 ohm range.One other thing I remember is I had a handrail chain rub a low voltage safety string wire intermittently, taking it to ground causing this type of error. Just a couple of thoughts.
PHP: 8.3.33 Page Time: 0.036s Queries: 22 (0.006s) Memory: 3.0111 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 12:14:28 UTC
