Posts: 422 |
Question You Guys,
I have friends that need to install a chair lift (sit down) in their home for an elderly Aunt. What would be the simplest and most bullet proof unit you would recommend?
Thanks,
Posts: 68 |
A stairlift? Harmar, which sells Summit lifts.
Human Volt Meter
Human Volt Meter
Posts: 10 |
Summit (Harmar now) is average at best and far from bullet proof in my opinion. The open rail system attracts dirt and requires constant maintenance compared to most. Also, the nylon rollers will wear out prematurely if not kept well greased. In addition, it's not uncommon for the unit to set the safeties going down with no load. If the stair slope is low or grease too stiff, then the unit will start bouncing and set the safeties. I found this to be a common problem.
I prefer Stannah as they have a far superior rail system and no travel cable to hang up. The cog system is in the back, tucked under the rail, faces down and is not exposed. This type of set-up is protected form dirt and falling debris. The simple brush system eliminates a travel cable and all the problems that come with it. I was also surprised to learn that Stannah has been in business for over 100 years. Sometimes time tested companies speak for themselves. ;-)
I switched from Summit to Stannah around 2008 and never looked back for many reasons. The Stannah reminds me of the old rugged Wecolator built by the Cheney Company we use to install years ago. This was before Access Industries took them over, and then Thyssen. We use to put in Bruno which was real crap for the first generation but got much better. Not sure how they are now. Anyway, that's my two cents.
David ____________________________________________________ It's a small world, but I wouldn't want to paint it.
Posts: 141 |
I use Stannah (Sterling Stairlift). They have been the most reliable, best fitting, best support system of the ones we used.Mostly my customers have been happier with them.
Posts: 68 |
Bruno units are good too.
Posts: 474 |
Posts: 237 |
We use Acorn. Not the smoothest unit at rail joints but just gets it done trouble free.
Posts: 422 |
Thanks you guys, think they are going Acron.
Work Safe
Posts: 1 |
I have two late 80s cheney stairlifts that need service. Anyone know where i can get install instructions. Or troubleshooting manual. [email protected].
Posts: 5 |
One thing that's easy to overlook with stairlifts is thinking only about the initial purchase price. In reality, it's worth looking at things like servicing, warranty cover, availability of replacement parts, and whether the equipment can be adapted if needs change over time.
It's also worth remembering that a professionally refurbished stairlift can be a practical option in many situations, provided it's been properly inspected, installed correctly, and comes with ongoing support.
If anyone is comparing options, I'd encourage getting a few quotes, asking plenty of questions, and making sure the provider offers reliable after-sales service rather than simply choosing the lowest price. A little extra research up front can save a lot of hassle later.
Posts: 805 |
Is Inclinator Co, still in business? they were/are the timex of chairlifts.
