Hi guys, I have problem with KONE,
is it possible fix that errors 0021 and 0102?
thatnks
[email protected]
has someone worked on it before you ??
What's the model
When was it installed
What have you tried so far..
The 102 is an over-current,it may happen when you try pulling through the Brake. you may want to make sure the Brakes are picking. Make sure they pick on a re-level. A 21 will be thrown almost every time you open the Safety circuit or go on inspection service. It will also happen when you have an error like a 102.
One other thing that can cause a 102 is a stuck Buffer Test Button. Usually though it is the Over-Current error.
had an issue similar to this a few weeks back, that fault came up with a 120-1025 fault if i remember correctly which was stating no current foun on leg. since i have updated drive software and havent had any issues since. it was a KDL16L
PHP: 8.3.33 Page Time: 0.023s Queries: 26 (0.006s) Memory: 3.0190 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 01:38:09 UTC
