#12895 12/02/14 08:50 PM
I've got an old Montgomery MOD into an Otis 211.
An incident occurred a few weeks back where it appears someone had tackled the top floor hall door causing it to dangle in the hoistway - this isn't the issue. I've repaired the damage to the door and hung out back on the tracks; however, now the elevator will not run. I can run it on inspection from the controller and car top but can not open the door from the controller. If I press the learn door button on the car top it will open and close doors with no problem. Now, It will answer hall calls but it will not open the doors. Instead, it'll sit at any floor level and just make a shrilling sound as if the doors have timed out. I have replaced the door operator board and it still has the same issue.
if anyone has some insight on this please help.
Much appreciated.
J. Clark
Is the controller acknowledging the door zone? Is the door open limit operating properly?
rac66 #12899 12/02/14 09:54 PM
The controller is acknowledging the door zone and limit appears to be fine
J. Clark
what operator do you have is it back off local
Still on local operation. When the car arrives at a floor, I bet you get DTO.
turn local switch off
Derick #12906 12/03/14 04:28 PM
On it! I'll see what happens. Thanks!
J. Clark
Derick #13022 12/16/14 05:10 PM
I'm sorry, could you elaborate what/where the local switch is - all switches I see on the car top & machine room are set to normal
J. Clark
at400 door operator controller on operator
Derick #13026 12/16/14 07:18 PM
where is the unit at and who do you work for?
Derick #13027 12/16/14 07:23 PM
Correction: found it. Don't know how I missed that, ha! I appreciate the help
J. Clark
PHP: 8.3.33 Page Time: 0.025s Queries: 38 (0.008s) Memory: 3.0503 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 17:41:04 UTC
