What is this?
Is this a hi-pot or does anyone know what it might be, hold the clips and crank and it'll light you up like a Xmas tree.
Posts: 563 |
I bet this is an old megger.
Posts: 366 |
Could be an old ring box, when we used to "ring" out the wiring during installation.
Posts: 366 |
Posts: 909 |
I believe it was called a Lucas Dynamo or Lucas Generator. I believe one of its uses was to charge and test capacitors.
Great collectors item!
Posts: 909 |
Rick, If you would, can you hook your meter leads up to it and post the DC and amp readings?
