0 members (), 40 guests, and 3 robots.
Can anyone help?
Thanks,
West
I believe the Lambda line has been obsolete for over a year now. Your probably better off replacing the whole detector unit because you cant cant parts for the rest of it anyway.
Yep, Lambdas are hard to come by at this time.
Just looking for cables. Anybody got some even used!
Shaking the Bush!!
Shaking the Bush!!
Lambda II cables are just a standard 9 pin cable. You can get them at most computer supply stores.
Hello Thanks for the reply. I ordered some on line.
Thanks for the help!
computer cables are not designed for flexing. Are also not labeled per code. NEC stipulates types of cables allowed for flex connections on doors and gates with exceptions for those specifically listed for that use.
try master elevator products, they have lots of new older parts.
Thanks!!! They have it! I was going to have custom cables made custom using proper cable.
PHP: 8.3.33 Page Time: 0.025s Queries: 30 (0.005s) Memory: 3.0307 MB (Peak: 3.5931 MB) Data Comp: Off Server Time: 2026-09-21 10:26:19 UTC
