#13688 03/17/15 08:06 PM
J-R
Does anyone have any experience with this drive? The elevator Is traveling up in the selected down direction.
Motor is a 31HP (Ac/Dc) Loher Motor, 5 Lead.
Has PM, UM, DM Contactors
In the up direction PM and UM pick as advertised runs up
In the down direction PM and DM pick but elevator travels UP.
- Runs on inspection up no problem.
- Put elevator at mid point - Not drifting up
- Down selected on inspection. Elevator runs in the up direction for 7-10 seconds, causes the drive to fault out.
- Sent drive out to see if there was any issues.
Drive installed and problem persist.
- Swapped L1 and L3 still travels up when down selected up.
- MCE says they dont know.
- GAL offered some Tech support on the Drive and they don't know
Voltage off drive
UP
2U-78v ac
2W-82v ac
2V-119v ac
1U-87v ac
1V-110v ac
Down
2U- 88v ac
2W- 92v ac
2V- 120v ac
1U- 120v ac
1V- 114v ac
Static
2U- 119v ac
2W- 119v ac
2V- 120v ac
1U- 59v ac
1V- 59v ac
I have the original Loher Technical description and Operating manual(PDF) if needed.
J-R #13689 03/17/15 08:47 PM
Does unit have load weighing?
J-R
Yes it does have load weighing. Peaking my Curiosity. I would assume it would just cancel calls... Honestly this hasn't even crossed my mind... The nights I don't bring the prints home im wishing I had them.
J-R #13691 03/17/15 09:11 PM
Is it calibrated right? If its off the the motor/drive may not be pre-torqueing enough. See if you can take it out of the equation, and see how it runs after that.
J-R #13692 03/17/15 09:12 PM
J-R
Sounds like your starting torq is too low. Check you tach!
jkh #13695 03/18/15 01:09 PM
Are you getting a voltage out to the motor in the down direction. It seems as though you may be opening the Brake and drifting. It may also be drifting in the up direction.
J-R
Bad motor...
This is a 6 lead motor with 2-1u and 2-1v.
2U~~~~~
2W~~~~~
2V~~~~~ Wired to the drive
1U~~~~~
1V~~~~~
1V-1u Inside motor casing, below dim rail Lugged together.
1v-1w
J-R #13704 03/18/15 08:49 PM
J-R
Only 5 leads are powered from the drive.
PHP: 8.3.33 Page Time: 0.021s Queries: 30 (0.006s) Memory: 3.0314 MB (Peak: 3.5924 MB) Data Comp: Off Server Time: 2026-09-20 21:21:18 UTC
