#789 11/03/10 04:36 AM
Troubleshooter
Troubleshooter
Anyone have thoughts on an error on the UIT "Ram Failure, CPU Shutdown"? Is the World Tool for this any good?
J Sand #790 11/03/10 11:42 PM
I don't think World makes a tool that communicates with the TAC 20. You may need to use the IMS tool to restore the Ram if it has failed.
Troubleshooter
Troubleshooter
tried that but couldnt communicate. bought a new board and going to install tomorrow. keep you posted.
J Sand #796 11/07/10 02:54 AM
Troubleshooter
Troubleshooter
Had to buy a new CPU board, reload software with Hyper Terminal, do a learn trip and done! Kind of suspicious since it failed the day TKE lost the service.
J Sand #16163 02/15/16 04:41 PM
underdog
underdog
Can you please explain how to you reload the software through hyper terminal?
Rav4guy #16164 02/16/16 02:17 AM
Connect serial cable to CPU 188E board.
Open Hyperterminal, create new connection.
Set Hyperterminal for COM1, BPS=38400, Data bits:8, Parity:None, Stop Bits:1, Flow Control:Hardware
Make sure JP2 has been removed from cpu 188E Board
Click Send file in Hyperterminal and select first job file (typically 4 or 5 files).
Place CPU in ZMODEM upload mode.
a. while pressing and holding rst button, press and hold the udl button.
b. release the RST button.
c. When the CPU STAT LED blinks 4 times, (2 long and 2 short), release the UDL Button
NOTE: CPU will stay in zmodem for 30 seconds, so if file transfer isnt started by then, you will have to place cpu back into zmodem again.
Click send on hyperterminal window. When finished, cpu will reset. When cpu finishes reset, place back into zmodem and continue with 2nd file and so on.
underdog
underdog
Thanks Rodney for your prompt answer, I have couple questions
Do you connect to the CPU board directly or through the bottom port on IO board?and what type of cable you use
Does this method works on 186o CPU board as well?
Do you need IMS software at all here?
Rav4guy #16220 02/21/16 12:41 AM
Yes, RS232 port with standard serial cable. You will need IMS to setup if you don't have a UIT on the controller.
underdog
underdog
Hi Rodney,thanks again!
Do you have instructions on how to set it up using IMS and do you need different cables or just the serial one.
I have a unit in senior building has been shut down for a week and I already got a new CPU board and I just need to bring it back to life.
What would be the next step after I sent the config files through hyperlink?
Rav4guy #16222 02/21/16 01:44 PM
Same cable. Run Hoistway Setup.
underdog
underdog
Then?
Rav4guy #16231 02/22/16 11:04 PM
Just make any adjustments you may need to. Should run with default adjustments.
underdog
underdog
Thanks Rodney for the help,the car is up and running.
Rav4guy #16264 02/25/16 12:06 AM
Glad to hear it.
PHP: 8.3.36 Page Time: 0.029s Queries: 42 (0.010s) Memory: 3.0641 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-06 07:53:48 UTC
