1 members (sampler),
Posts: 4 |
Anyone have information on fault code 97? Manual I have only says consistent breakdown. Not much help.
jj5
jj5
Posts: 22 |
I think that's the slack cable switch at top of hatch. it should still run on insp. I was told some of the newer installs have one on both sides. The one I have on service is just on the one side. I don't have a manual so I found this by trial and error. What type of manual do you have?
Posts: 4 |
I was left with a generic owners manual. No useful information in it.
Posts: 170 Likes: 2
Posts: 170 Likes: 2 |
Correct answer. I've worked on a few of these. NOT the best product I've ever seen. I think that's the slack cable switch at top of hatch. it should still run on insp. I was told some of the newer installs have one on both sides. The one I have on service is just on the one side. I don't have a manual so I found this by trial and error. What type of manual do you have?
GDB
GDB
Posts: 80 |
Does the code 97 come up when the system is reset??
if so it is a status code and one that does not seem to been in the European manual
To read the fault codes you need to go into menu 50
and if its a fatal error you can reset in menu 10
Posts: 4 |
Thanks for all the info. The software needs to be upgraded and I also have an interlock issue.
Posts: 18 |
elevator blocked from running. ive found that the time and date gets corrupted randomly witch puts the belt time stamps overdue and blocks the car from running. have also had all the belt time stamps get corrupted and caused the same shutdown. WELCOME TO THE "TRANSIT CONNECT" OF THE INDUSTRY. also euro manual useless. diff beast.
Posts: 170 Likes: 2
There should be a metal template on the job for setting the interlocks. I've found that the guys in construction are not setting them properly and it creates a lot of problems.
Posts: 7 |
97? But where? error on schindler should be something like 00 70. 4 digits error number, read on menu 50.
Que la salse non acabe.
Posts: 4 |
Posts: 170 Likes: 2
That is not the fault. That is the mode, condition of the unit. There is another code that shows the actual fault that put the elevator into that mode.
GDB
GDB
Posts: 80 |
If you upgrade the software you will find the menus will become restricted
If you are not Schindler don't let them upgrade the software or next time you force a shaft learn you will be able to configure the COP
Sneaky bastards!!!
