0 members (), 27 guests, and 4 robots.
Hi All! I joined this forum for some guidance and expertise. I am an owner of a two story medical office. My Otis elevator was put in at the time of construction 10 years ago. We did not use the elevator for initial 4 years and didn't have heavy use till summer of 2014. (The upstairs was never fully occupied until then). Since the increased use last year we have had repeated problems with the hydraulic oil leaking out into the pit. Re packed in 11/2014. The tech that did the repack warned us that he saw scarring and evidence that one of our pistons was ground down. He states this damage could have only happened at time of install since the piston is never really exposed. Is that true? Is it possible for me to damage the piston from light/ moderate use or is it a manufacture defect? He is recommending we tell Otis that they need to fix it because it is basically a manufacturer defect. The piston was not in good condition on installation and was bound to cause all these problems....then my packing completely blew this week and all the oil leaked out and of course the elevator is not in service. i have spoken to Otis over the phone and they of course are not admitting anything. They are recommending a sanding sleeve to fix the piston, which I will have to pay for. Is that a good solution? My tech says that a sleeve will not reach the entire piston....any insight into my situation would be greatly appreciated. Thank you so much!
Sanding sleeves are installed at the head of the jack, and as the elevator runs, it mildly sands the piston down. This is used to remove nicks, dings and scratches from a piston that has multiple points of issue. It wI'll reach 99% of the relevant parts of the piston. By simply using the overtravel and hand sanding the remaining 1% all of your piston that could go through the packing will be sanded.
That being said I find it odd that you had a leak, were re packed, and then blew the seal completely. Just reading here, it sounds like the repack may have been faulty as I would have expected it to simply leak again. The damage on the piston must be pretty substantial, as all re packs I have ever done, I checked the piston for marks to sand down as I did not want my brand new repack to meet the same fate as the old seal.
No your usage should not be held accountable for any damage to the piston. If the elevator was left in the down position for those first 4 years, and someone cleared the head of debri, it should have worked straight away. If the elevator was left up, there is the possibility of rust developing on the piston due to moisture in the air. 4 years of it would be substantial enough to damage your seals.
Hope this helps, and if you are in doubt, get a few bids from competing companies for the repair. You may be surprised by someone else's assessment. Good Luck.
I agree with Silly.But my question is do you know if unit is a hole less or conventional.
I experienced a similar problem with an Otis replacement jack assembly. When the jack was installed, there were several vertical scratches running in lengths about 2-4 feet. Oil usage was excessive-to the point where it the drain line from the head of the jack wasn't able to keep up with demand when relieving it into a scavenger pump. We installed a piston sander and allowed it to run for several weeks, and then re packed the jack.
All was good for about 2 months-oil consumption was very reduced and the pit remained dry. Then a service call revealed oil all over the pit and first floor sill. The elevator had pumped all of it's oil into the pit. After the car was hoisted out of the pit, the culprit was a blown packing. It had fractured in a line around the circumference of the packing. It was determined, after consulting with Texacone, that it was a faulty packing, and unrelated to the earlier jack issues. Another packing was installed, and for well over a year the unit has been trouble free.
As long as your service provider takes appropriate action to correct any issues, this shouldn't become a long term issue. In our case, we were willing to stand behind the product and correct any issues, with the ultimate goal of making the customer happy through whatever means necessary.
Good luck.
All excellent comments. One thing I would add, your service provider should have examined and dressed the piston BEFORE they repacked the jack. If the dressing is not done before hand, it will destroy the new packing. This is most likely a Cemco jack, they did make a quality product.
sorry just seems the people that did the repack are trying to absolve themselves of blame.....if they were any good they would have NOT repacked it if the scoring was that bad...and did they use an OEM or equivalent packing or some mom and pop type. 10 years is a bit of a stretch to try to get ANYONE to take the blame no matter who installed it!!!
Kiwi this one does seem to have a smell about it!
it is holeless
Thank you so much for your detailed thoughts. I am really learning a lot and hadn't thought at all of the idea of a faulty packing job. Well, now that some time has passed, I had the same vendor who did the packing 6 months ago, return yesterday to fix the blown packing. After reading your post I didn't know if this was a good idea because he could have been the original problem, but the appointment was set and I felt like I didn't have the time or trust to go with someone else. Anyway, he gave me the texacone seal from the blown packing. It is very interesting. The green seal has over a half inch wide "groove" where it is worn away at a specific spot. He says this supports his theory that there is a problem with the piston. He originally thought the piston was ground down creating flat spots for oil to leak through the seal, and degrade the seal prematurely. Now seeing this groove it looks like there is a large nick or bump that is causing the wear. What do you think? I contacted Otis and they don't share that theory of course. They think that the piston was not aligned correctly causing it to wear the seal at that point. I cant' visualize what otis is saying because if the piston was not aligned I would think that the wear would be larger than a half inch, that the wear would be nearly one half side the the seal from the tilt or angle of the piston. Thank you for sharing your thoughts
Also if a piston has been ground done what does it look like? My piston looks like it has a pattern on it, like ripples/waves, my tech says that is what grinding looks like. When I compare that to my other piston in the elevator, the other piston doesn't have that wave/ripple pattern. Can grinding alone cause such oil leakage problems? If a piston was ground down, was Otis supposed to tell me at the time of install?
I will see if I can figure out how to post a picture of the seal....
How did you determine the texacone packing was faulty and that it wasn't a bad pack job from your provider?
I added pictures to the photo gallery. Sorry I don't know how to link to this post. Please take a look
Looks like the piston wasn't lined up or the packing wasn't installed right. A cut in a packing from a big scar in the piston of that size would have severe leaking in a matter of days. Did the company run the piston up to check for scratches/welding slag? The cross hatched sanding pattern in your pics looks pretty normal for those jacks.
Just curious why you didn't call Otis to re-pack it? If anything they know the unit the best. These jacks are usually not leakers and are very easy to check the piston for scratches and are one of the easiest to repack.
Also, 10 years for a packing, running or not, is well past its typical lifespan.
Did the service provider check the alignment of the jacks with the rails? Are the rails straight and plumb? there does appear to be some rub wear on the packing, this makes me think we have a jack, rail alignment issue here. The piston does look fairly normal, without touching the piston myself, its hard to make a call.
I didn't call Otis to repack because I was worried that the issue was the piston and didn't necessarily trust them to give me an honest opinion. Also when Otis installed the elevator 10 years ago their service was horrible and expensive so we haven't used them since. I am also not questioning the first pack job that Otis did 10 years ago, but this all started when the non-otis provider told me that the piston was bad and that the repack may not last due to grinding on the piston. Now it seems he was just trying to get away from responsibility of a back pack job? So if you are telling me that the picture of the damaged packing looks like the piston not being aligned and not a piston issue then I guess I just paid the wrong guy to do a bad job again. I don't know if he ran the car up and aligned the rails....isn't that standard to do? I will ask him
Standard is a loose term. Standard for me on a leaky repack is to first run the car with the bad seals still in place checking for damaged pistons and repairing them as needed. Sanding is a normal way to do this, and when done correctly has absolutely no problem with the new seal. Using a power tool to do this task can cause flat spots that may carry oil.
Alignment typically is a rather simple process, where was the piston for the first 10 years? Brilliant idea is to put it right back where you found it. I usually mark the platen hat, take measurements, etc. to ensure I have replaced the darn thing where it has lived very happily for a decade.
Again this issue may not have been with the provider, or the packing, or may have been one of them, or both. The spot on the seal looks very suspicious to me in that the slight arc visible looks like a very small radius in comparison to the over all seal radius. Seems to me that if the alignment of the piston was bad, that you would have had an elongated seal (oval) and not a roughly 1 1/2" spot. This could have been done by foreign debri, piss poor install of packing that caused damage, or a bad spot on the piston or joint if the piston is sectional (not sure they even have sectional twin posts, just a thought).
If I had to guess, I would say the piston has damage, horizontal, that is "eating" that section of the packing. The repair contractor should have addressed this issue at the time of the repack. It's like changing brake pads on a car, and not making sure the calipers are in working order, all you do is burn though another set of pads....
PHP: 8.3.33 Page Time: 0.095s Queries: 44 (0.059s) Memory: 3.0732 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 11:21:14 UTC
